PTFE or Paste?
19 May 2007
When and where should you use ptfe tape and when and where should you use jointing paste? Can these ever be used together and when shouldn't they be used?
It would be great to have a clear understanding of this.
Lay-co slic tite is good stuff
On gas Only use gas grade ptfe and never use both as it causes a reaction and then leaks one or the other on gas
As a general rule;
PTFE TAPE - if you're sealing a thread eg. wind some clockwise onto the thread of a radiator tail where it screws into a radiator.
JOINTING COMPOUND (Boss White) - put a light smear on an olive just before you push the olive and pipe end into a compression fitting.
N.B.
Don't use PTFE tape on olives.
Tap connectors don't need anything except their fibre washer - just make sure the nut is quite tight.
Others may disagree with the above. It was what I was taught, and has never let me down.
Sorry if I appeare a little facetoius, but the original poster did'nt specify what he wanted to seal :D
and as a matter of interest, slic-tite does most everything, £15 a tub could be a little off putting though, even if it is good for steam i still prefer to use foliac :wink:
