Greetings and Salutations
Approx three years ago we had an extension built and the builder at the time put in situ pipework for a replacement water main. This went through to our cellar where the remainder has sat there coiled waiting for something to happen. The builder didn't come back to finish the work so has remained an unfinished project.
We are now lifting the floor in the room at the front of the house where the pipe needs to run however I have a couple of queries that I would welcome some input on:-
1) does the pipe have to be one continuous run from the front of the property to the rear?
2) does the pipe have to be anchored/clipped to the floor joists or can it just sit in the cold space under the floor?
3) does the pipe have to be in a conduit?
4) if the pipe work can be done in sections then this would be more manageable, do I need to put a stop cock at each join or is there a specific fitting?
5) when I bring the pipe up into the front garden how much do I need to leave above ground?
We don't envisage getting the main connected this year but we will be completing the work on the room that pipe will traverse and also the front garden area where the pipe will emerge into
Thanks all.
Thanks all.
