Puma 80 pilot keeps on going out
10 Jul 2011
Cheshire
When i switch heating on the pilot goes out its ok for hot water just the heating any hellllllllllllp
No circulation. Overheat causes pilot cutout.
Dead pump most likely, but can also be a stuck diverter valve
unscrew the black central plastic octagonal thing on the pump. Put CH OR water on and see if pump's spinning.
hi just taken te black thing off and the motor is running both with central heating and hot water then the pilot went out because heating was on
What happens if you turn the CH control knob back to near the minimum?
