pump blowing fuses
Rob
14 Aug 2006
London
Can some one explain the reasoning behind it.
The boiler is a vaillant thermocompact. i.e turbomax plus system boiler
New pump 6 weeks ago as it had failed and AFAIK is now the cause of blowing the 3A fuse.
With a correct ohm reading across the motor (175) what is the cause of the failure? Or any other thing to look for?
Many thanks :(
Any ideas what caused the old pump to fail? sludge/scale?
Maybe the same underlying problem is what is causing this also?
