Have an Ideal Icos m3080 with no internal pump (only external)
It had failed with L8 code.
FanDC volts were low, so PCB needed replacing.
Have bought refurbed PCB.
Also thought it best to get new fan as I read here that these can be an issue, taking down the PCB. New fan resistance 106 ohm, & certainly looks new.
Just installed both, but it blew mains supply 3A fuse.
A couple of more tests, and on third blown fuse, the PCB fuse has also gone.
I've now run the external pump from separate supply with 3A fuse - no problem.
All other non-boiler mains eqpt connected, no blown fuse, so it must be internal to Icos.
Any ideas welcome.
(Off to Maplin, who show 3.15A quick-blow fuses in stock)
Any ideas welcome.
