    Dismiss Notice
Pump CH water to outhouse automatically?
Discussion in 'Plumbing and Central Heating' started by loply, 15 Jan 2019.
  1. loply
    loply
    11 Jun 2013
    288
    Thanks Received:
    29
    Country:
    Hi folks,
    I want to put some a pair of underground heating pipes over my garden (about 25 meters) to an outbuilding to power a radiator in there.
    I think it's too far for the combi boiler to pump by itself so I was going to help it by putting a seperate pump on that pair of pipes.
    When I've installed underfloor heating before, the Grundfos pump they supply you with automatically turns itself on when the flow gets warm... So that's what I want to install, a pump which will come on whenever it detects the inlet pipe is getting warm.
    Only trouble is I can't seem to see how the underfloor heating setup does this, and none of the pumps I can buy seem to say anything about how it works.
    Any advice?
    Thanks,
    Rich
  2. Sponsored Links
  3. Rxt_ian
    Rxt_ian
    21 Sep 2016
    8
    Thanks Received:
    Country:
    Wouldn’t you want it set up as a separate zone? Add another diverter valve, with a thermostat and timer to trigger a pump and the boiler indipendantly for that zone.
    Saves you heating an empty outbuilding every time the heating is on, or even worse over heating the house trying to warm the cold outbuilding.
  4. bernardgreen
    bernardgreen
    3 Nov 2006
    22,104
    Thanks Received:
    2,048
    Bedfordshire
    Country:
    I think running the primary heating circuit ( the circuit that feed the radiators ) 50 metres under ground would not be a good idea.
    You could consider a secondary ciruit to the outbuilding and couple this to the primary circuit by a heat transfer unit.
    Any faults / leaks / antifreeze in the secondary circuit would not affect the primary circuit and house heating.
    Only run the secondary circuit pump when the out buildng needs heat ( and the boiler as well )
  5. MrBenchmark
    MrBenchmark
    25 Jan 2007
    1,401
    Thanks Received:
    236
    London
    Country:
    Would keep the grass nicely defrosted though
  6. ivixor
    ivixor
    4 Feb 2010
    438
    Thanks Received:
    50
    Cambridgeshire
    Country:
    Don't do it. Install an electric oil heater and a timer or smart plug to control when it turns on.
  7. muggles
    muggles
    28 Oct 2005
    11,065
    Thanks Received:
    2,195
    Oxfordshire
    Country:
    That's going to either cost a lot to install, or a lot to run. Which one it is depends on the quality of the installation. The proper pipe to run this in is Uponor Thermo Twin (or similar), which is £60 per metre. If you do it in that, you shouldn't lose too much heat to the ground and it shouldn't significantly increase your heating bills. If you're expecting to lob a couple of lengths of Speedfit in a trench with some cheap grey insulation round them, however, you can expect your heating bills to be quite high and also expect it to freeze in the Winter when you've not got it turned on, because that stuff ain't waterproof.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
