pump not working
25 Sep 2006
Edinburgh
Hi, I have just come back from holiday to find that, when i switched the central heating/ hot water back on, that my power shower doesn't work. It has next to no pressure and i can't hear the pump actually firing up. I usually have to place the shower head in the bath to prime the tank and then once the pump makes a higher pitched sound then it is fully primed. Now it just dribbles hot water without any noise.
As i have just moved into this house 4 months ago i don't know how or when it was installed.
Any ideas on how to fix this? :cry:
cheers
You haven't got enough head of water to push the air out of the pipe and create a flow to turn the pump on. (Should have been a Negative Head pump really). While you've been away the air has settled.
I'd use an aquavac to suck the water through the hose and pipes, but if I was feeling lazy I'd remove the shower head and suck on the hose!
thanks for the tip. I have tried to suck the air our myself. Not the nicest experience for a monday morning, but i dont know where to get a suction pump from. How long do i do this for?? It doesnt seem to be working yet.
