please can someone confirm how a pipe stat(same as cylinder stat) should be wired up to allow a pump to over run.i know but am having a bad day.
i put swl to normally closed &
perm live to normally open but it worked in reverse
No - if you turn the dial down it's like the boiler temperature has gone up, ie above the set point, which you just moved. So the pump would get its power from permanent live.
Wouldn't mind a fiver for every time I've done that, always long enough since the last time that it catches me again!
