Even if the programmer is off for both water and heating, if I turn the boiler stat up until it clicks, the boiler lights. The heating doesn't get hot but I assume it's heating the water. The pump in the airing cupboard is also on all the time, even if I turn the boiler stat all the way down so the boiler turns off. After investigation, I discovered a box next to the pump with a label on it that says 'valve actuator'. On top of this box is a switch which appears to be generally to the right. While the pump was playing up, I moved the switch to the left, it moved itself back and the problem goes away for a couple of days, only to return later. The more astute among you may have spotted my heating engineering skills are not my strong point so any (simple) words of advice would be appreciated - ie. what do I need to buy???
Dave
Dave
