OK, has anyone had this problem?
I went on holiday for a week and turned my hot water system off.
I have a gas boiler with a tank, a controller, a motorised valve and a Grunfos pump.
When I came home the hot water would only heat up by bleeding the pump. Before this the motorised valve just kept on turning and would not park at the hot water position. Now, two days later, same problem.
I think it is the motorised valve switching, or sludge in the pump causing problems. Any ideas?
The boiler does fire for the few moments when the motorised switch is pointing at the hot water position on its travel round. Problem is, it just won't stop there.
Any advice greatly appreciated.
