What pump speed is perfect for a Worcester Bosch 28 junior combi? I read it must be on 3 but I've turned it down and can't tell any difference?
In the cold weather if I set the temp at 19 it gets there easy and doesn't fire that much
If I set it higher then 21 it struggles but the return temp hovers around the 55 degrees this is with the boiler on temp 5 out of 7 if I go higher it won't condense I suppose as the returns higher then 55 degrees
Systems all been sorted and flushed radiators are roasting
An I just asking too much
