Hey!
Furry friend of mine wants to pump his hot water. He organised the pump between the cylinder and the top outlet.
I pointed out that the outlet was acting as an overflow/pressure relief into the header tank in the loft - effectily the highest point hot water could go in the pipe. If he pumps it it'll just **** into the tank!
His cylinder is in a garage attached, and to run another pipe to act as overflow/relief will be a lot of work. Is there any gizmo we could attach to the tank to substitute?
