Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Any system which is pumping over is wrong, regardless of blockages. You need to get this sorted, as all sorts of problems are there, which will shorten the life of the whole heating system.
This is more common that people think. There is a hard sludge build-up where the vent and down feed pipe meets the return pipe just before the pump. It has to be cut out and cleaned or replaced.
The blockage at this point is not normal sludge but seems to contain calcium which makes it very hard indeed.
HCl will dissolve it but thats not a good thing to use on copper pipework so it always has to be cut out. Its also virtually impossible to drill through it.
The pump was changed about eighteen months ago, which may have coincided with the pumping over starting - thats why I'm wondering if its possible to fit a pump the wrong way round .Thanks
