Hi all - I have got to go to a toilet as it is leaking into the bowl - the lady says that the water level is way below the central tube that gets pused by the buttons - any ideas?
Non-syphon flush valves (as in WC cisterns with push buttons) often leak due to grit, limescale, etc., on the seating at the bottom of the valve assembly. In most cases, the valve body can be unlatched and removed without tools (and no force!!), and the seating cleaned.
