I have hired someone to renovate the bathroom.
We are having a new shower, bath, basin installed in a different layout to the existing layout. We agreed that we would have copper pipes for all work.
I have come home and found that pushfit fittings have been used in certain places. My personal preference is always copper and that was what was agreed before the work started.
The contractor has said they were not able to use copper in certain places.
I wanted some opinions on the following work so far:
1. Is it ok / reliable to put push fit onto copper pipes? Could they come off due to the pressure? Is it more likely to leak with the transition between copper and plastic?
2. The reasoning I was given about the shower pipes is that it was next to the plasterboard and that soldering there could damage the plasterboard? (I would think there is something flammable resistent that could shield the plasterboard?
3. Would it be possible to replace all of the places where the pushfit has been fitted with copper?
4. Would these elbow joints be difficult to replace with copper elbows
5. These are going from 22mm to 15mm - would it be better to reduce with copper solder?
6. These are the old pipes. Would you use compression fitting or solder end caps?
7. I was told these plastic pipes that will go to the basin and they are plastic to make it easier to go under the existing pipes that are already there?
Thanks in advance.
Thanks in advance.
