I want to replace the push-fit plastic fittings with brass compression fittings as one has sprung a leak and flooded the loft. Removing the fitting where the leak is was easy - it almost fell off. I cannot remove the other end or another fitting that I want to change. I don't want to use force. Can somebody please tell me the "easy" way and if I need a special tool? Thanks. Roger
