PVA vs Primers
21 Apr 2010
Lancashire
This article was written by Alan at AT Stone who is a Professional Tiling contractor, He now mainly specialises in natural products but over the years He has fixed every type of tile there is.
I have to give guarantees for my work (many of these projects are commercial such as sports centre showers and changing rooms). For me to be able to give guarantees I need to follow strictly the specification of the adhesive manufacturers.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specify that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
OK why then? Well I asked this question to Ardex when I once had problem, I'd tiled a bathroom that had been constructed in 25mm Marine ply. Thinking he was doing the right thing, the builder got his guys to seal the ply with unibond PVA...I wasn't aware of this.
I tiled it and 6 months later every single tile fell off the ply, the adhesive solidly stuck to the tile but came clean a whistle off the ply.
We had Ardex Technical down to the site to compile a report, the basis of which was it's the PVA that causes the problem.
When you treat a surface with PVA it partly soaks in and partly sits on the surface of the substrate much in the same way as wallpaper paste.
If PVA gets wet it becomes slightly live again, it doesn't completely return to it's liquid state but it becomes sticky.
When you spread tile adhesive onto the wall, the water in the adhesive makes the PVA live and stops the adhesive from penetrating the substrate and providing a mechanical grip. Basically your tiles, grout and adhesive are being held to the wall by a thin layer of PVA.
Most tile adhesive works by crystallising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so what's the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier. They also stop a chemical reaction occurring between the cement based adhesive and a plaster substrate, a known problem know as "Ettringite failure"
I hope this clears up any misunderstandings.
So only use PVA before tiling if the adhesive manufacturer specifies it in the instructions.
Well, that's not the first time I have read that, I think Mudster (Alan Mudd) first posted that some 6 years ago and I have seen it copied and pasted on virtually every tiling forum ever since. Shame Mudster doesn't browse forums anymore, knowing him very well, I'm sure he would be a little embarassed to see that little lecture still being posted.
It reminds me of the WP1 application guide I did with photos, I was sick and tired of seeing it after a while and they still have the thing on Ultimategimpman website, do people not update these things?! I would like to see the thing taken off, considering I was banned from the forum.
Hmmm Bathstyle, I posted this to educate the majority and try to be of help to people researching. Alans words are still factual, I'm sorry you are bitter about something.....about what I do not know.... and do not care.
If you don't have anything positive to add to my posts then please add nothing
In which case........ That is a fine copy and paste Gaz, I'm sure many will find it incredibly informative.
I have know of the AT Stone article for quiet some time & although have posted links to it many times on here myself, have never replicated the detail. It's useful info to repeat IMO but no matter how many times you warn against it, with almost monotonous regularity OP’s will post about using standard PVA when tiling & even some "trade persons" advise it; some have also used it to prime new plaster before painting which is a total disaster. PVA seems to be regarded as the cure for all ills but whilst it’s a big asset in some situations, it's not suitable for many others; most are not waterproof & in mnay cases there is a more modern & suitable alternatives available.
Only use standard PVA on a tile base if the if the adhesive manufacturer recommends it but if they do, my advice is pick another brand of tile adhesive :LOL:
Tune in next week when Gaz will be reminding us of the pitfalls of eating yellow snow
If you are getting water behind your tiles it's time to pull them off anyway PVA or no PVA.
