Hi there guys ,yes the run was measured using the Pedometer??(I think that how its spelled),But i'm grateful to you for your remarks,I knew inside that it was a no go-er for this work,I will pass on this info to the people cocerned ,that they will have to negotiate with the elec/company to bring the O/H line right up to the house,and from hence run the pvc armour into the and instal a service head,thanks again.
Yes, whatever, you're going to need an FOBB of some sort to terminate the ginormous SWA into - either a busbar chamber or an isolator/switch fuse.
But...
Any switch or switchfuse designed to feed ginormous SWA is surely going to be designed to handle humongous currents? (I love these technical terms )
In this case 185mm² would be used not because it's a 400A load but because of volt-drop, but who's going to be making switches that you can terminate 185mm² into without them being able to handle 400A?
And that sort of switchgear has got to be pretty expensive - markedly more than a simple box with some sturdy copper bars downstream of what would only need to be the sort of switch you find as an incomer in a domestic CU. Or a 63A MCB.
I guess compared to £10K worth of cable it's trivial though.
I'd second the suggestion to up the voltage somehow - I suggest either a 2-phase or split-phase supply transformed at the other end, or even at both ends, depending how the economies work out with the cost of the transformers.
