Hi all, hoping someone can point me in the direction of a supplier of pressure rated plastic pipe of various diameters.
As some of you may have guessed already I'm not using it for its intended purpose, but instead for building strange and curious pneumatic devices.
I'm looking for pipe with a 2 1/2 inch inside diameter to use as a lanuch tube appropriate fittings and valves to handle a reasonable pressure (50-100 psi)
and some significantly larger pipe (>4 inch diameter) to use as a pressure tank.
So far most suppliers I've spoken to have eiterh only stocked 32mm and 40mm "standard" pipe or want all the money in the world for minimum orders of 10+ meters per pipe.
Any clues for the clueless ?
Duke E.
If you can't make someone happy
Make them Chocolate Fudge Cake.
Duke E.
