Pyronix enforcer menu key tone
16 Nov 2017
I had a quick search but didn't see anything. Can the key tones be switched off when using the keypad in the menus?
It's pretty annoying when scrolling through the menus.
Thanks.
Press and hold D then enter 2000 security code. Takes you into keypad internal menu, volumes can be adjusted there. Press A to save and escape menu.
Thanks for the reply managed to adjust the keypad key tone down so alot quieter now.
Pressed A to save and the alarm went off, saving alarm fail. Fine now after I shut it off but s**t myself.
Think that mean that the control panel is no longer seeing device 0 the keypad. Try setting and unsetting the alarm and see if it clears.
It’s a glitch on those panels, earlier software! Once you come out of the keypad menu, the system briefly looses coms with the keypad and shows an RS485 error. Just clear it by resetting alarm in the usual way.
