Pyronix Sterling 10 - replacing PIR?
3 Apr 2012
Kent
Hi all,
Have an ancient Pyronix Sterling 10 in our house. Last night it went off twice, same PIR. Vacuumed it out in between and there’s nothing around that I think might have set it off, no droughts, no radiators, no balloons. Thinking of just replacing the PIR. Is there anything particular I need? Was looking at a Pyronix pet one as we have a cat although it’s shut out of the room that the PIR triggered in normally.
Any gotchas I need to be aware of?
Looking at this:
When was the last time the backup battery was replaced, a failing battery can throw up all sorts of problems.
Probably about 10 years ago. I hadn’t considered that. It’s been ok since my last post - if it does it again I think I’ll take down the pir and vac it out. Any more grief and I’ll probably call somebody out; it’s at least 20 years old and given the invasive stuff has been done presumably it would be relatively easy to replace with a more modern system and PIRs using the same wiring?
Should be changed every 4/5 years or when any issues show up.
A failing battery can show up in a number of different ways.
