how do you get qualifie to isolate the incomeing suply to pull the main fuse and add an isolator between there an the DB
A 25% error rate is not good.By learning to spell and express yourself in a coherent manner would be a good start.
Have you not got a spell checker installed.![]()
The Google toolbar one works fine.As to spelling I have just re-installed windows and Firefox and I did have some problems getting spell check to work. It seems you need to down load the plug-in for language used and simply clicking on use spell check is not enough.
It indicates a slapdash nature, a lack of interest in taking care, a lack of interest in doing a good job.I think to criticise on the spelling is rather petty
Just our of curiosity ..... Whilst I'm all in favour of safety, and of respect for that which needs to be respected, what hazards (other than contact with the live feed, either carelessly or due to distintegration of fuse or holder), needing of the degree of protection you indicate, do you envisage could result from pulling a DNO fuse that was carrying no current? (and, since spelling & grammar have been mentioned in this thread, I suppose I should add that I'm sure that my old {'Victorian'} English teacher will be turning in his grave at the sight of that sentenceIf you understand the problems with ionisation of the atmosphere you would not want to draw the DNO fuse. Those authorised have to wear a fair bit of PPE. Large rubber gloves, goggles, and other flash guard clothing. Of course no nylon that is banned. Anything which will melt rather than just burn is a no no. i.e. no florescent waist coats.
Talk about the Grocer's Apostrophe (or should it be Grocers Apostrophe? )![]()
The precautions are not solely there because of the equipment being worked upon. Rather the approach is that when working in the vicinity and on any live equipment the PPE shall be worn. OK fair enough the gloves only when pulling/replacing the fuse and when actually working on the cut-out.Just our of curiosity ..... Whilst I'm all in favour of safety, and of respect for that which needs to be respected, what hazards (other than contact with the live feed, either carelessly or due to distintegration of fuse or holder), needing of the degree of protection you indicate, do you envisage could result from pulling a DNO fuse that was carrying no current? (and, since spelling & grammar have been mentioned in this thread, I suppose I should add that I'm sure that my old {'Victorian'} English teacher will be turning in his grave at the sight of that sentence
Many feel they can draw the fuse if the DNO has failed to install an isolator.
No he didn't.Sorry TTC you got that back to front
