Query about first floor extension Side Elevation Windows
2 Oct 2007
Sussex
Hi
RE: Query about first floor extension Side Elevation Windows
I’ve read that there are restrictions regarding first floor windows situated on a side elevation, such as obscured glass, or sill height minimum of 1.7m etc.
My question;
Is there any flexibility if the nearest property has no windows whatsoever on their side elevation facing my property and is some distance away?
If yes, any idea of the distance required?
Any other help regarding side elevation would be appreciated as our property is a chalet bungalow with Velux windows.
The property is long with windows at front and back, but the majority of rooms/windows run on either side elevations.
Before we contact an architect we would just like to know if our thoughts to convert upstairs to semi or full ceiling height would be worth doing.
The upstairs first floor has full living accommodation but most of the footprint is lost as the height of the walls finish at the top of the ground floor windows, so most of the space either side is just loft space, and the degree of the roof slope means only a small amount allows full head height.
Typical bungalow style.
Thank you in advance.
Regards
Stephen
In planning terms, there are no 'restrictions' as such on side elevation windows. It's just that the development would not come under the umbrella of permitted development if your windows were clear-glazed and had conventional-style openers.
Your planning department could possibly agree to you having clear glass - you would need to discuss this with them as it would depend on the circumstances of your case.
Hi
My question;
It varies between councils and with the angles/heights of properties involved - in one parish I'm pursuing an application in at the moment, it's 14m to the side and 21m to the rear.. Particularly ludicrous when one looks at the density of the adjacent housing
Only you will know in terms of the cost versus the value, but contacting an architect will be sure to add quite an amount to the cost. Consider an architectural technician instead
I'm not sure I this means the upstairs is already converted, nor am I certain what a typical bungalow is.. Is it a hipped roof or gabled?
