Question about Combi boiler system
21 Jan 2013
Yorkshire
I have a boiler on order from British Gas (a worcester 30SI), and I'm in the process of removing the old boiler system in the house.
So far I have removed the following:
1. Cold water storage
2. Expansion tank
3. Hot water tank in the bathroom
Is this correct
I take it I don't need these anymore. Also there is a diverter valve which I won't need.
Do I need the water pump thats in there at the moment, or will the worcester 30si cope without it?
Thanks,
Matt
You'll have been well ripped off for price if you are having a british gas install.
Why are you doing anything leave it to them.
I suspect he is hoping to get a few pounds back by selling them!
But he could have saved about £1000 getting an independent to install the new boiler!
Tony
Thanks for the replies but they aren't really much help.
As for the price, I've gone with British Gas for certain reason, which are irrelvant to the question.
The reason I want to remove the stuff is to gain access to other areas while I completly renovate my house. If the stuff isn't going back then I might as well fully remove it now and not worry about it.
You don't need any pumps in the system.
Hopefully British gas have measured your flow, pressure and that a combi is suitable.
Out of curisoity how much are british gas charging.
I would have done a conversion to a boiler with better performance than
the worcester for about £1600 give or take depending on location.
OK thanks,
I'm paying quite a bit more than that, but I've added lots of extras, such as the radiator flush, extended plumbing, moving the boiler (so new brickwork) etc etc.
Can't remember the exact price now.
Flushing the system is not an optional extra! It must always be done!
But British Gas price it as if it was optional but a must have option!
Bit risky taking bits and pieces out, could cause a flood.
