In the gravity system.
If you are calling for stored hot water, and you have the central heating on at the same time, I understand that when the DWH reaches 60 degrees, the zone valve will close and shut off the boiler to prevent the boiler from cycling.
If you want to keep the CH on, how is this achieved if the boiler is shut off?
Does the boiler interlock not kick in if CH is switched on by the programmer?
Sorry if I sound dim, my pack doesn't explain this.
Thanks.
Thanks.
