I understand the keep warm facility on combis should ensure a quick delivery of hot water, but could somebody confirm:
1, If a tap turned on, off and then on again in reasonably quick succession if only hot water will flow even if the combi had stopped firing; and
2, Can you run the hot water at a low level and still receive hot water - I believe on older combis a certain flow rate is needed for it to fire and heat the water?
Many thanks
Many thanks
