Quick question
14 Jul 2004
Worcestershire
Every electrical joint/connection should be in an enclosure,so when fitting various lights in domestic properties most lights do not have the means to do so,(connectors pushed into the ceiling).
Could anyone give advice on such connection methods,or do inspectors overlook it.
For flush fittings (no ceiling rose) the enclosure at the back is sometimes formed by the body of the light fitting, and whatever it is screwed to 'the fabric of the building'. Wall lights are really bad for this, as choc block is often stuffed in an inadequate void.
Ideally a box should be set into the wall or ceiling, particularly if the wall or ceiling is potentially flammable, and I find round dry lining boxes go quite well in the ceiling in these cases. In reality this is often not done by many installers, and the accident rate suggests the risk is small in practice. Similarly the fact that live contacts can be exposed without use of tools by taking the bulb out of most traditional fittings, is clearly not really a problem either, despite sounding horrific when you say it. So in summary not good, but not uncommon, and not life threatening if a little thought is used to avoid the silliest of installations.
Most light fittings have a means of enclosing connections. If not, you can use a small jb or chocbox.
Some fittings the cowels are to small to hide a small junction box in the ceiling or even plaster roses especially when you can't get the floor boards up above so your are left with just connectors.which i guess is wrong
