This is most likely a silly question so please forgive me in advance....
In an unvented system, does the radiator loop just go via the boiler or is it routed via the hot water cylinder too? For example, if the water in the cylinder is cold, will this affect how quickly the radiators get hot?
I get that there are separate options for 'hot water' or 'heating' on the control unit but wasn't sure if the hot water option just closed a valve to stop the flow around the rad loop and that when the heating option is chosen it also heats the cylinder water.
