My property needs some roof repairs but none of it is particularly DIY friendly so I've got a couple of quotes with massive variance. Just wondering what is reasonable?
We have '4 roofs' all pitched - it's a Victorian end terrace. The front and side is a gable end where the edge is probably around 20ft from the ground with the apex being around 30ft it's a very steep pitch as each has a room inside.
The back is a gable end where the edge is around 10ft from the ground and apex around 20ft there is a loft space but no room so less steep pitch. Finally the side has modern single storey extension with concrete tiles.
There are some slates loose and missing on one corner of the front roof. Apparently it's because the fascia board has no capping on this side, so the wind has lifted them. There's also a slate missing higher up and on the other side one missing from under the ridge tiles.
The front bay window lead flashing has pulled out on one side. The first floor bay window has a very slow leak to the lead capping in very specific weather - driving rain or snow. Looks like it's been a problem for years.
The middle roof has a slate or two missing.
The back roof has a slate missing from under the ridge tiles, two of which have no pointing around them - unsure if they are loose or not. The fascia board also has no capping on one side either.
The modern single storey extension has a 'wet ridge' to the gable end which is all cracked with gaps etc. and would be good to convert to a 'dry ridge' instead. The length of the 'wet ridge' is probably about 6m in total with a little bit extra at the front either side of a small porch area.
The first quote I've had is from a recommended roofer - £2,800 with scaffolding to the front, no breakdown of costs. Will repair the main area of loose slates at the front and fix new UPVC capping to whole fascia, refix lead to bay window, says first floor bay window probably just come movement and needs sealing. Will convert wet to dry ridge.
Said the back probably didn't need scaffolding but when I asked about this seemed reluctant. Nothing in writing just given the price over phone.
The second quote found the roofer online - had lots of good reviews and member of a roofing organisation - £11,800 which I honestly thought was for a full reroof of the front roof! It's for scaffolding the front and part of the side, everything has been put in writing but no breakdown of costs, repairing all the loose slates, new UPVC fascia board, full reroof of bay window and pointing etc. chimney stack (says it may as well be done at the same time - although I don't see any issues with it).
Doesn't include conversion of wet to dry ridge.
Makes the first quote seem really cheap! Just wondering what is a fair price to pay?
Thanks in advance, chaoticj.
