Rad - back panel hot, front panel cold
18 Oct 2006
Surrey
Fitted a double radiator in the summer to replace a single. The new rad has been relocated to under a window. Any reason why the back panel should get blazing hot but the front only luke warm?
Have you vented all the air from the front panel (if the two panels have separate air vents)?
It just has the 1 bleed valve which does both sides - which ive bled
Could sludge from the system have got into the rad and blocked the channel to the front panel? Other than that I can't think of any possible explanation, unless there is a manufacturing defect.
