Hi All! Am replacing a smaller imperial sized rad with a wider metric one. The old rad brackets are attached directly onto plasterboard with those anchors that you attach with a setting tool. The wall is now tiled with ceramic tiles , except where the brackets are. (I tiled around the brackets.) Question:- The new rad will need new brackets in a different place which will mean fitting them onto the face of the tiles.: I can't see how I can fit wall anchors over the tiles - there are teeth that dig into the plasterboard - also the force needed to set them might crack or split the tiles..... are there any alternative anchors I could use?
If there are any ideas, could you please give specific details of model and make, and pref. something I can buy from a shop rather than online....
Thanks!
Thanks!
