I'm having the kitchen plastered and think I may have to take the rad off the wall so they can do behind it..
it's only a small rad ( single sided, 500 wide )..
can I drain it without draining the rest of the system?
turn the TS valve all the way down and turn the locksheild off?
should that work and be ok for a few days?
would you recommend fitting blanks to the valves just in case? ( presumably the TS valve would open if it dropped to cold? )
