HI
Can anyone advise me please,i need to change a Radiator in a downstairs bathroom and put a bigger one in and will need to alter the pipework to suit,in the past i have used a Plumber to to do a similar job and he did not drain the system,he used drain plugs in the pipes somewhere in the header tank in the loft ,i presume to cause a vacum hence stoping the flow of water, could anyone explain this as it sounds like a time saving idea,i have a Baxi boiler in the chimney breast and firefront and header tank in loft is this a open system?
Paul
Paul
