Hi
I've just fitted a new radiator after first draining the system and then refilling. The new rad is only getting hot at the bottom and not the top. I've bled every rad where possible (3 don't have a bleeder valve) and switched the pump on and off quickly to try and get rid of any air.
What concerns me more is that when I try to bleed the new rad (a double with fins as opposed to the single one I had before) neither air or water comes out. It does absolutely nothing.
Any ideas?
Any ideas?
