Radiator fitting
18 Oct 2009
Hampshire
Hi
I'm replacing the radiator in our downstairs loo after a full refit with a Reina Slimline 600mm x 400m.
I want to replace the valves and thermostatic valve however struggling to find valves with a 10mm compression input? Does anyone have any suggestions?
Also is there such a thing a mini or micro thermostatic valve as its a pretty tight area and it would be ideal not to have a huge thermostatic valve
Thanks, appreciate it may be a silly question
10mm valves are commonplace and a google search comes up with loads. You could also use a reducing set in a 15mm valve if required.
ae235
+1 for reducer make sure you crack it remove top and ptfe then put top back on and crack on as usual
never seen a mini TRV but they do come in different sizes depending on the manufacturers,
Drayton TRV4 are pretty slim and are good quality
you could put the TRV on the other side if there's more room
