radiator flow
22 Mar 2004
I've re-hung a radiator on an opposite wall and have had to reverse the pipe entry,meaning the flow of water is now entering where it used to leave.Will this have an affect on it's operation and will bleeding it cause a problem?
It will make no difference at all. The only thing to check is if you have a TRV fitted. Some of these are sensitive to water direction so it's best to ensure that this is on the inlet. Bleeding the system will be unaffected.
