I've recently had my central heating balanced,as the front room radiator (last in the chain),was hot at the top,& cold at the bottom.
This was great,& the rad was working correctly.
However, within a week or two,it's reverted back to the above state,& this morning i've noticed it's stone cold.
My boiler is a Valiant Turbo Max.
I've tried for bleeding in the system. (There's no air found).
I topped up the system to 1.0 on the pressure bar (1.5 when it's on),as was recommended to me.
No sludge in the radiator,as i hosed it through about a month ago when i decorated that room.
As it's been balanced just a month ago,it heated up fine then,& it's slowly deteriated to it's previous state since,so i'm guessing it's not the balancing either!
i had another problem last week with pressure dropping,which i've now found to be a leaky TRV valve in an upstairs rad. That's now fixed,but it's not made any difference to the front room radiator.
I Even went to the point of turning off all the other radiators EXCEPT the front room radiator,but it was still luke warm/cold.
The radiator before in the chain (bottom of the stairs) works fine,so i'm assuming it's a problem with this paticular radiator.
I Can't shake the feeling that the fact it's the last one in the chain may have something to do with it.
If it'd been an upstairs rad i could have lived with it,but this is a main one in the front room & needs sorting.
Any ideas???
Any ideas???
