All upstairs and one down stairs radiator, which is the bottom of stairs at the front door are red hot. The one in the living room and the one in the kitchen a just tepid warm, thermostat turned full and they have both been bled dont now what else to try
Allow me?
Turn the hot rads right down using the lockshield valve. I usually close them completely then open them 1 turn.
This will cause the hot water to circulate through your cool radiators - water always takes the easiest route around the pipework. keep TRV's fully open when you do this. With luck, if balancing is the problem, this will sort it.
