We have 14 radiators in the home. 3 of the highest ones are in the 2nd floor loft. The small one in the loft bathroom is fine, have to bleed it a tiny tiny bit every month or so to get it piping hot otherwise it’s nice and warm.
The other loft radiator is in the bedroom and since around April 2022 has stopped heating up at all. We don’t even hear any gurgling air trapped sounds that we once used to.
We had a professional power flush of the whole system and each individual radiator done (the proper way of isolating each valve etc) as we had a blocked boiler heat exchanger. All was good. All radiators were properly balanced using thermal heat cameras to check the flow temp to each rad and valves adjusted accordingly.
The cold radiator concerned had an Aladdin auto venting valve fitted to one side and seems to work ok. Whenever I try and bleed the same radiator on the other side, no air comes out, only cold water - so the auto venting valve must be working.
I did replace the broken Drayton TRV4 head because god knows what happened to it after it power flush but it was broken and loose. Even without the head on I pressed on the pins several times gently whilst the heating was on high temp to loosen any debris blocking it etc but still didn’t get hot.
The only thing I haven’t tried is adjusting the other lock shield valve because it has been balanced. I guess I’m left with no other choices so will have to try it bur I can’t possibly understand what the problem maybe as there is zero heat at all coming to it.
Have I missed anything? It was working fine and hot immediately after the power flush. We didn’t use the heating during the summer so can’t tell exactly when any problem manifested. It’s been like this for at least 6-9 months now.
