- Joined
- 26 Feb 2018
- Messages
- 9
- Reaction score
- 0
- Country
Hello,
I have an annoying problem with one of my radiators in upstairs bedroom. I have had the house refurbished and all radiators that were against an inside wall moved under the window of an outside wall. The central heating was working all fine while we were still working on the house. I have however been living inihere for the past month and the radiator either goes off completely making it stone cold while heating is working or likl it is now only part of it heats up.
I've already taken the radiator off and flushed it outside where a lot of black water was washed out of it. I've reppacedrthe trv and the valve on the other side. Whole system was then ran with sentinel x800 cleaner for nearly two hours and emptied of all water. Also been refilled and all radiators were bled.
Now the problematic radiator heats off the trv side about 5" towards the middle and whole top. On the right hand side however it sits lightly warm and the outlet pipe is cold asawell as the bottom ofothe radiator.
I am now clueless as to what else can be done to make it work the right way as all the other radiators heat up instantly and stay hot.
