    Dismiss Notice
Radiator problem - may be return valve
Discussion in 'Plumbing and Central Heating' started by SteveSmithBris, 7 Dec 2017.
  1. SteveSmithBris
    SteveSmithBris
    7 Dec 2017
    2
    Thanks Received:
    Country:
    Hi, I've got a radiator which is not heating up. My first thought was to bleed it, but when I do that water consistently comes out under pressure - there's no air. I think that means water must be flowing into the radiator OK in order to maintain the pressure, so my assumption is that the fault is the return valve (or whatever it's called, the bit where water flows out!). Does that sound right?
    If so what should I do to that valve to fix the problem? I've attached a photo of it.
    Many thanks,
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    15,584
    Thanks Received:
    5,561
    Lanarkshire
    Country:
    no you assume wrong, you will have to close each valve one at a time , then do as you tested open the bleed valve and see if you have a continuous flow, if you have a faulty valve you will not get a continuous flow with only that valve open, the water will come out regardless of flow or return so that is why you have to close one then open it again then do the same with the other
    • Thanks Thanks x 1
    • Like Like x 1
  4. terryplumb
    terryplumb
    8 May 2017
    3,870
    Thanks Received:
    779
    Country:
    What type of valve on the other side of rad ,is it a TRV ? Might be the pin stuck if its a TRV.
    • Thanks Thanks x 1
  5. SteveSmithBris
    SteveSmithBris
    7 Dec 2017
    2
    Thanks Received:
    Country:
    No, not a TRV. I was assuming the main "in" valve must be OK if there's pressure in the radiator.
  6. Sponsored Links
  7. terryplumb
    terryplumb
    8 May 2017
    3,870
    Thanks Received:
    779
    Country:
    As ianmcd stated above water enters from both sides , when pump is operating water flows in / out the rad. If you close that valve make a note of how many revolutions it needs to close ( or part revolutions ) as you will need to return it to its original position ,in order to maintain balance.
    • Thanks Thanks x 1
    • Like Like x 1
  8. Hot&Cold
    Hot&Cold
    16 Jun 2017
    1,539
    Thanks Received:
    272
    Country:
    The picture in #1 the butchered spindle would need some consideration,is it fully open ?
    • Thanks Thanks x 1
    • Like Like x 1
  9. DH6
    DH6
    16 Jul 2011
    475
    Thanks Received:
    79
    Durham
    Country:
    That valve looks closed to me
    • Thanks Thanks x 1
    • Like Like x 1
  10. HERTS P&D
    HERTS P&D
    9 Apr 2010
    10,058
    Thanks Received:
    1,490
    Hertfordshire
    Country:
    That valve needs replacing, I would be fitting a TRV as it looks like it was too hot and someone attacked it with a pair of grips.
    Andy
    • Thanks Thanks x 1
    • Like Like x 1
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
