radiator size 8m2 18m3
10 Dec 2010
rough idea please cold bedroom i have 900 x 600 single radiator 1m2 of window area stone built cottage 8.2m2 floor area 18m3 volume. 3 outside walls, according to the radiator size i have its about 923w and i calculate 984w, looking to replace with possibly a double does this sound as if it will be better heat... 1609w....
Is the window double glazed? Plastic, metal, wood?
Is your room north facing?
Whats ther floor above? Insulated? How much?
Solid brick wall thickness?
double glazed plastic 10mm air gap i beleive
floor above is attic ceiling with 50mm insulation
stone built property solid 24inch thick
room is end of a terrace with two walls facing east and west, and the big longest wall 4m facing south, window is on the east side facing a high mountain gets very little sunlight in winter. floor below is living room heated space.
