    Dismiss Notice
Radiator Valve Replacement
Discussion in 'Plumbing and Central Heating' started by mikedelderfield, 8 Aug 2008.
  1. mikedelderfield
    mikedelderfield
    4 Jun 2003
    13
    Thanks Received:
    Country:
    Hi
    I am planning on replacing a radiator valve. Is it essential that I replace the olive on the pipe valve connection?
    Looks to me like there are risk in removing the olive e.g. damaging the pipe or the pipe being distorted. Are there any risks with just leaving the olive and nut on the pipe and attaching to the new valve?
    Any thoughts would be gratefully appeciated.
    Regards
    Mike D
  2. Sponsored Links
  3. spacethegas
    spacethegas
    23 Jun 2008
    1,213
    Thanks Received:
    2
    Wiltshire
    Country:
    no problem
  4. mikedelderfield
    mikedelderfield
    4 Jun 2003
    13
    Thanks Received:
    Country:
    Thanks for the post spacethe gas.
    Does "no problem" mean that I can leave the olive on the pipe?
    Regards
    Mike D
  5. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    there is always some risk either way, for example the threads may be different so replacing the nut and olive would be reqired, nut and olive may be in excellent condition and so not need changing. Experience is the key here but that cannot be explained.
  6. DCPlumbing
    DCPlumbing
    17 May 2008
    70
    Thanks Received:
    Sheffield
    Country:
    Some fittings also differ in depth so the olive might not seal correctly.
    An easy way to remove an olive is to carefully cut partly through the olive with a junior hacksaw at a 45 degree angle without cutting the thinner edges ( the olive is thicker in the center than its outer edges) Then insert a thin flat blade screwdriver into the slot and give it a twist, The olive should split and pop off. A bit of PTFE when re-fitting won't do any harm.
  7. spacethegas
    spacethegas
    23 Jun 2008
    1,213
    Thanks Received:
    2
    Wiltshire
    Country:
    there you go.
    couldn't be easier.
    famous last words.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
