Hi, ive recently accidently drilled a hole through a water pipe, thats repaired not problem but i cant get one of the radiators to heat up. I assume theres air in the system somewhere, ive tried the obvious ie bleeding and shutting all of the other radiators off opening the problem one up fully but still it does not heat up.
On my last attempt i drained some water out from the bottom of the radiator and it did start to get alittle bit hot at that time but not this morning.
My system has a pressure vessel if that makes a difference, i am making sure its got pressure in it.
If this makes any sense to anyone then please can you help?
Thankyou
Thankyou
