    Dismiss Notice
Radiator wont heat up!
Discussion in 'Plumbing and Central Heating' started by Scotto81, 9 Jun 2010.
  1. Scotto81
    Scotto81
    9 Jun 2010
    2
    Thanks Received:
    Renfrewshire
    Country:
    Hi Guys,
    Hope this topic is in the correct place, I have looked on various forums but can't find teh answer, so hope someone can help.
    I stay in a 1 bed flat and the bedroom radiator wont heat up, has been like this for a few months now. To check if there was a blockage, I bled all radiators (5) in the flat, shut off the vales on them all apart from the bedroom and turned on the central heating at a high setting for 1.5 hours to see if any blockage would be flushed out, but still no joy.
    When I look at the radiator in question, the thermo valve is on the left hand side and the right hand side has the (apologies if incorrect term) flow restriction valve.
    The thermo valve was taken off and it doesn't look damaged, but even when the heating is on there is no heat in that side of the pipe whatsoever. On the other hand, the flow valve pipe does get a little heat when the heating is on.
    The sitting room radiator is the furthest away from the heating system and you need to walk past the bedroom to get to the sitting room, so I think the issue must be with the valves in the bedroom - as I don't think the sitting room radiator would heat up if there was a blockage.
    I'm no expert and I don't know the layout of the pipes under the floorboards, but I suspect the vales in the bedroom might be shot? Any ideas from anyone? I don't want to be lifting carpets etc unless I really have too. Thanks
  2. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,077
    Thanks Received:
    1,083
    Norfolk
    Country:
    Although you have removed the TRV head there still may be an issue with the pin stuck down or the lockshield valve on the other end may be closed.Check those out first.
  3. Sponsored Links
  4. Scotto81
    Scotto81
    9 Jun 2010
    2
    Thanks Received:
    Renfrewshire
    Country:
    More info - when the heating is on the TRV pipe doesn't heat up at all, but the valve pipe does, not much, but a little.
    The TRV pin is ok, it moves up and down without any issue, I checked it there.
    Is it strange that the TRV pin is ok, yet that side wont heat up at all?
  5. ianniann
    ianniann
    22 Mar 2009
    678
    Thanks Received:
    91
    Manchester
    Country:
    The problem may be the valve at the other end from the TRV.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
