Radiators back to back wall
16 Jul 2009
Hull
Whats the best way of dropping pipes down a stud wall to put radiators on it back to back?
Not sure what you're looking for as an answer? Cut a section out of the plasterboard and run the feed down inside? Size depending you may get away with running them both off of a single 15mm. If they are any larger than say 1200mm long then ideally you want them on their own. Minimises any balancing issues.
Is the stud wall existing? If not then use copper or plastic and install as per recommended guidelines.
