Not sure what type of system this is but assume it is not gravity fed as there is a pump. The water in the system is fed by the mains with no means to fill by hand.
Boiler is sitiated behind the fire on ground floor, hot water cylinder is on first floor and has honeywell controls, system is approx 20 yrs old.
On the valve near the boiler there is a slider which says auto at one side and manual at the other end, this is at auto. There is also another 'thing' which has a dial which is numbered 1 to 3, it is set to 2. When turning to 3 it seems to fire the boiler up, is this correct?
Two of the three rads downstairs heat up when the hot water is on, even when the thermostatic valves are turned off. The control radiator upstairs also heats up when hot water is on. A new radiator was fitted recently, the system was drained and then re-filled, this it would seem has caused the system to play up.
Should something extra have been done when the system was re-filled? Why do the radiators heat up even when the rad thermostats are turmed off, why are only some of the rads heating up?
Any help will be much appreciated.
