Now that the weather is colder, I've noticed that some of our radiators are not hot enough, even when the Drayton Lifestyle thermostatic rad valves are up to max. None of them what I'd call really hot. Potterton Prima "F" boiler on 5, i.e. next to Max. Does cut out (in the garage so haven't yet checked out how often and for how long but wasn't firing when I went in there a little while ago) so not underpowered. I took the head of the worst rad as it was a bit loose. The pin was out but I couldn't depress it with a flat object as I believe one should be able to. Put the head back on, doesn't wiggle now but no improvement in the rad temperature. I've checked that there is no air in and the rads are warmer at the top than the bottom. Small bore pipes. The system is supposed to have Sentinel in it so shouldn't be sludged.
Some of them don't turn off even when put back to zero. More than one rad in each room so I can compensate for that. I suspect the pins are stuck but if the pin is stuck out, shouldn't the rad get hot enough?
Any suggestions? Could the pump be on the wrong setting (though we haven't altered it and we were warm enough last winter)?
Very sick husband who feels the cold and unable to deal with this problem.
