Radiators not working but...
26 Jul 2015
I can't balance them because when im closing the lock shield valves on most of them they start leaking.
1. Pipes before the rads stone cold are not warm
2. One of the rads was on a few weeks ago before putting some x400 in, that has stopped
3. Another rad was partially working but now after a drain today has stopped and is stone cold.
Another thing to add is I'm doing a bathroom Reno so I've removed the towel radiator, they are stone cold too now.
All rads working are blazing hot to touch.
Typical as the one broken is in the living room!
Can you post photos of the lockshield stock see if they can be just tightened on the nuts?
Here you go not sure i see any nut or is that the brass section at the bottom.
How many rads don't heat up currently ?
Close the TRV ( or wheel head if no TRV) on all rads that currently heat up.
See if any cold rads now heat up. Report back.
Ok so those being tightened has sorted that bit.
I will be avoiding this one lol
In the morning i will shut all possible off to work out if its balancing another issue going around is some of these wheel head valves are stuck as well.
Ok, closed all of the rads except two not working, one worked and the other didn't, I suspect the one not working has a frozen TRV.
I will have to replace that in a few weeks when the x400 I put in does its thing as I thought it might had been a blockage.
Rads now back on.
Thanks for the help.
If a radiator isn't heating up there is no flow through it ,so the x400 will do nowt as far as that radiator goes.
