Hello, I have a vented system with independent motorized valves for heating and hot water. The heating works fine, boiler comes on and off controlled by the room thermostat, all radiators get hot. Trying the just hot water, the boiler comes on runs for a short time then switches off, pump stops and valve closes.I can feel the pipe warming up both sides of the valve. Left alone it tries again about an hour later. I thought tank thermostat, so I disconnected it, boiler did not come on at all (as expected), I shorted it and the boiler did the running for a couple of minutes trick. I think this means the thermostat is OK. I thought air lock, so I turned the pump up to max and can hear the water circulating and the bottom of the coil gets slightly warm before the boiler switches off. Now I'm stuck, some guidance as to where to look next would be appreciated. Thanks
